- Joined
- Apr 21, 2005
- Threads
- 115
- Messages
- 26,084
I show part number for that bolt is 71382-60010. May still be available. Showing a price over $7.50 which would suggest part is more than a simple bolt.
I heard back, the 71382-60010 bolts are NLA per Amayama. I figured that was the case but it was worth checking.
Unfortunately not able to help for a while.
Here are my measurements from Louie...I'm trying to figure out the location of the tire carrier hinge holes. The body shop did not keep this piece, and the new rear sill doesn't have any holes in it for the bottom hinge. If I get the location of the top left hole, I can figure out the rest from there. Looking for the distance from the center of the hole to the rear opening and top of the tub rail. Thank you.
When we did that as a professional carpenter (for accuracy to eliminate the s***ty hook which means almost all the time for finish work) working in a team (or alone!) we would shout out “Burning an inch”. You always knew what you did when you held up your piece and it was exactly one inch short..Note the caliper measurement starts at 1 on the ruler so you need to subtract 1 from the ruler dimension.
