just a couple simple brake related questions, firstly, I purchased a full "set" of 8 brake cylinders, they all have the same piston size, I know that originally had the fronts were slightly larger 1.11-1.12" , mine are all the smaller of the two sizes, .997". is this going to be a problem?? And secondly, the Toyota Repair Manual says,
"Caution, there are two kinds of adjusting nuts and the bolts. The adjusting bolt of the left-hand threads is on the right side of the rear brake, and the right-hand threads bolt is on the left side of the rear brake."
Does this means, that on the left side (U.S.A. Driver side) of the truck, the the left- hand treads would be toward the rear and on the vehicle, and on the right side (U.S. passenger) the left-handed thread would be towards the front of the vehicle, or are they referring to the sides of the axle???
also why? i assume its to simplify the direction of adjustment?
thanks
thanks
