- Thread starter
- #41
Cut out the center of the strap.
Cut the two halves together to flatten them out.
Fit check.
Fit check.
I think they should be flat from the door hinge pillar and follow a straight line down the taper of the hood. And flat top to bottom. Is this correct?
Thanks for the help
Can anyone tell me if my assumption is correct. The front gill panels on the tub are bent in toward each other. One is bent a lot more than the other. The bend is a curve (not a wrinkle) that I should be able to straighten. Just don't want to straighten something that should be curved.
Thanks for the help
