- Thread starter
- #241
The black just needs the hardener added, shake and spray. Scary at first but you get over it. The pressure and distance control the texture. If the first coat isn't the right texture then you can change it with the second coat. I didn't cover the bolt holes. It's thick enough that it doesn't fill the holes. You have to really work to get the spray into inside corners.
Edit:'I needed to run a tap with my drill/driver in some of the holes to clean up some paint.'
The tintable needs color added. The color thins it a little so the texture changes. Requires increased distance for a fine texture. First coat close up to fill the inside corners then the second coat further away to adjust the texture. Lots of stuff on Youtube. Once its cured, its hard as a rock.
