I'm pushing to get this thing rolling, with a stretch goal of running, so I can move it to a new spot and tackle some fab work.
Progress up front. Tldr; front axle is reinstalled.
I still need to connect brake lines, mount wheels, reattach the front driveshaft, fill with fluids, and re-torque everything.
I kinda hoped I could use this 70 series front brakeline, but this axle housing is lacking any and all mounting points. I'll tackle adding some later.
For now, quick n dirty.
Starting from the caliper, I dunno if this retaining bracket is bent or oriented funny but using a 12" steel line from Oreilly's, I bent this hard-line to do a 180. The soft line (a Dorman H36937, a hair over 10" overall) is not in the greatest position either, but it doesn't stretch or pinch so I'm moving on.
OK, so this is ugly. Embarrassingly so. I will address this later. But anyhow, I needed a coupler for the male hose end to the male hard-line fitting, so this one is held in place by zip-ties. Same thing on the other side.
I don't have a bracket with a captive nut on top of the housing to use the more common bracket for this t-fitting. I took this one from a breather so it already had a 3/8" hole. I reshaped the bracket so it could fit on a diff nut, and bent the bracket in a vice to point it to the rear.
I ran the rest of the lines using the easily bendable copper-nickel tube and terminated using a bench vise flaring tool.
Since I have no mounting points or clamps on the housing, I got these 3/16" tube clamps with 3/8" mounting holes from inline tube.
The breather is from a 60 series.
Much of this will need to be redone, but if it doesn't leak, maybe I'll drive it rather than tow it.
