Wanted 58-67 carb insulator plus more parts
Looking for a few F parts;
1 bbl carb base insulator with PCV tube.
Heat riser manifold gasket between intake and exhaust.
1 bbl gasket for the top of carb.
1bbl air cleaner to carb clamp and bolt.
PM here or e-mail pardion@comcast.net
Thanks, John
John, the Ford 300cid engines from the 70’s use almost the same gaskets and carb spacers as the old f135’s. The only difference might be a smaller mounting hole diameter, but you can easily punch them out bigger. You won’t be able to find a carb spacer with a PCV port, but it may be something you could fashion yourself.
Edit: just reread and realized you’re looking for the gasket on top of the carb. IIRC, I see those on eBay regularly.
one side has some chips in it, could maybe be fixed with some kind of JB weld?
