5 Tire Rotation Pattern.
Washington, MO
Spare to PS Rear.
PS Rear to DS Front.
DS Front to DS rear.
PS Front to Spare.
DS Rear to PS front.
Am I doing this right? I've never done a 5 tire pattern.
Response belongs on Pirate
After searching Mud for Rotate, Tire rotate, spare, Rotation, tire rotation (I'm not going to sit here and read every post on tires) I just wanted a quick answer so I could rotate them tonight while the wife is working out.
None of the titles including the FAQ thread helped. I guess I should have stated that in my post prior to posting.
I should have just started with google. I found the answer, without the smart ass abbrieviations.
If I had found the answer after searching extensively on Mud, I would't be posting in the first place.
Sometimes Mud tech responses belong on Pirate, not here. That's why I stopped using pirate as a resource for tech info. There you can barely ask a question without being basically called a dumbass.
:censor:
I take a bit of a different method. In my case, the front left wears highest, then the front right, then the back left... so...
I use a $3 depth gauge to determine which tire has the most to least tread. I put the one with the most tread remaining on the front left and the least on the spare mount.
:censor:
All I said was it's in the owner's manual. You don't have one of those? I'm sorry if I offended you with the flipoff smiley. I'll be sure to never use that again in a response to you. :frown:
Maybe you should have done a search on rtfm. :D
:censor:
:confused:
with over 100 posts you should know that :flipoff2: is more of a term of endearment than anything else here on MUD.
and wob's right...it's in the owner's manual.
:flipoff2:
The one in the lower right gives me a headache trying to figure out what goes where:
I don't think it matters one bit if you rotate often enough. It'll average out.
I go around in a circle, just easier to figure out. I have the wheels numbered also.
I rotate every 3K or 5K.
[said with a blank expression]
I'm supposed to rotate the tires?
Don't they rotate while I drive?
:grinpimp:
That's because FAQ's don't generally cover stuff that's ITFM. :flipoff2: I think you're suffering from PPS (Post Pirate Syndrome) and read a little more into wob's response than was there. You should be in a better mood if the wife gonna be out tonight :D.
hmmmmmm
OMG! :eek:
I KNOW I'm supposed to rotate tires (do it on my Cutlass a few times annually) :doh:
But... :o:o:o
I've had the damn truck since August 2005...
and...
haven't done it yet
hanging head in shame
Guess I know what I'll be doing this weekend... :D
But... :o:o:o
and...
haven't done it yet
How the hell could I fail to remember to do something so basic?! :eek:
Especially since I do it for my Cutlass???
OMG!! :mad:
*kicking myself in the head*
Little known fact - you don't have to rotate the tires if they are the stock LTXs. Most people try to wear them out faster to upgrade, but there is nothing you can do to hurt those danged things. If all vehicles were to switch over to Michelin LTXx, the tire companies would go broke.
Maybe it just seems that way to me.
:confused:
:confused:
Painfully true, my PO put on smaller than stock LTX's, they looked used but with lots of tread when I got it, turned over 106K on the test drive, rolled over 168 last night I still have 10 or 20k on those tires, :crybaby:
I have not rotated them in along time, maybe 30K? and the fronts are getting a little more worn than the rears. I think I am going to do a 4 wheel rotation to them one last time just to keep the VC happy, the current spare has a patch so it will stay there.
when these wear out gonna go with 305/70 BFG AT KO's
Painfully true,
Must be why I am lucky and have not yet had cause to regret my stupidity...
I wish I could come up with a good reason to justify buying 5 new tires.
If just 2 went on me... I could convince hubby that it's the right time to buy bigger and better. ;)
Spare to PS Rear.
PS Front to Spare.
dug through the OM for you and that is not what it calls for
spare -> Front Left
Front left -> Rear Right
Rear Right -> Front Right
Front right -> Rear Left
Rear Left -> spare
personally I would go with the measure method, put your lowest tread to the spare, next lowest two in the rear and least worn in the front.
spare -> Front Left
Rear Left -> spare
Correct.
Spare to PS Rear.
PS Front to Spare.
spare -> Front Left
Rear Left -> spare
OK, now I'm really confused :confused:
This is what I have in my owners manual:
Is the rotation different depending on year? (mine's a 97 TLC btw)
That is exactly what I do. Rotate them clockwise and not worry about it. I do them every 1k since I'm only putting on about 5,000 miles/year.
