- Thread starter
- #41
Did you set up the gears yourself, or a local shop?
Big D's Off Road did the setup on R&P.
akarilo said:Big D's Off Road did the setup on R&P.
For reference, can some of you post up what your tire size, diff ratio and speed/RPM is in low range? I am attempting to determine crawl speeds/RPM for various diff ratios.
Also include if the number is O/D on in highest trans gear. Thanks, Terry
Didn't think I'd get lucky enough for a Tulsa shop.
Are you still considering the Marlin TC gears?
5.29 36"(measured) low range OD 3000rpm = 33mph
5.29 36"(measured) low range 1st 3000 rpm = 9mph
