What are the best reasons for either?
Ford powerd /C4 71 FJ40
Thank's!looks like I'll be the first to say it.... search. It's in the upper part of the page. Read the recent threads on this and then you will be more prepared to ask specific questions.
This has been covered and recovered. That said, I'd go soa. Little more complex, but seems to be where most of us end up.
If you have the option, drive a couple of both that were done right and make your decision from there.
SOA is cheaper
this is not true if done properly, steering is going to run you at least 500
that was just the hysteer for methis is not true if done properly, steering is going to run you at least 500
mr. green do you have any rub issues?
The best reason for SUA: you wheel mild trails and are happy with some clearance and somewhat limited flex, you are capable of bolting on the lift kit yourself but cannot cut/turn/fab, you don't like the extra 2" of lift from SOA and don't like tippiness![]()
QUOTE]
sua can still wheel the hard trails. most of the leaf sprung rigs on our chinaman run in april were sua and they did just fine. chinaman is rated an 8 trail. and flexy...just look at treeroot's rig. his flexes better sua than many soa's.
QUOTE]
