3rd row seat quick release?
Kamloops, BC
Website
www.forgottenbc.ca
There's a lot of posts out there about people permanently removing their 3rd row seats... but I don't want to do that. I use mine often enough. However, when we go camping or need the space, I do need to actually remove the seats (not just fold them up).
Is there really no easier way than to unbolt the 2 bolts holding each seat to the bracket? Most vehicles that have the 3rd row seats (even my Wife's caravan) seem to have a "quick release" of sorts so you can remove the seats easily...
I know it's only 4 bolts, BUT... getting them back in while balancing the seat up is a real PITA. I can't believe there's no quick release on the bracket. Please someone tell me I'm wrong!!!
First of all thanks for the porn! Nice photo! Yes there is a way to disconnect the seat from the bar that is bolted to the wheel well. I took mine out so long ago I can't remember the exact procedure but it a bit of a hassle. I'm sure instructions can be found in the owners manual.
Haha, no problem. I figured any post asking questions would get more attention with porn attached ;)
Very interested to hear how to do this. I looked closely at the bracket and for the life of me couldn't figure the darned thing out. I'll see if the chassis manual I have has it. I don't have the original manual (user manual) as it didn't come with the HDJ81.
I found the manual (I did have the 1997 owners manual in PDF)... and it said this (with not really any wording either. Just "follow these illustrations to remove or fold up the rear seat").
But... it doesn't do anything when I try that! Lol. From what it looks like to me, the thing is welded around the pivoting part of the seat bracket. How could it slide forward or back?
Is it possible the earlier models didn't have that lever? I really can't find it... haha.
What the illustration is telling me is that I flatten the seat, fold it up against the window, unclip that little arm, fold the seat (back down?) Push the lever (that I can't find) towards the outside of the vehicle and slide the whole seat forward while it's face down?
Here's what I have... I just went out and took some pics. Couldn't find any lever. :(
First, pop the support bar loose shown in step two of the diagram above with a quick hit with the palm of your hand. Then lift the lever up shown below that is located in the front of the bracket. It's spring loaded so you need to hold it up and then pull back an inch or so on the entire seat and that should allow it to be lifted off.
My seats definitely do not have that lever! Damn. Must have been a change somewhere in the years. Now I need to find a set of brackets that have it I guess.
I would love it if you were correct about this Jon, really I would... but there is no quick release lever. I don't know why.
First picture.. are you talking about the little thing? That's a piece of the vecro cloth, look @ pic 3 to see it more clearly.
ON a side note ( I know this is not the FS/WTB forum, I will make a sep. post on there soon...) does anyone have a set of brackets with the quick release that they could sell me? :)
Weird. Mine are 1 piece. It looks like the one ppc posted, but it's permanently attached to the bracket pole. I guess that being said I would need to replace the bracket AND that portion of seat. That black "hand rest" piece that has the lever under it is attached to the seat by 2 bolts (underneath the seat)
Looks like that "Lock Assembly" is available everywhere except Japan so hence possibly your problems?
78910-60020 LOCK ASSY, FOLD SEAT, RH
78920-60010 LOCK ASSY, FOLD SEAT, LH
Here's for the US (and rest of world) model... I am assuming if (assuming IF) part 78910A/20A bolt to my seats, then I could potentially purchase:
78910A (RH)
78920A (LH)
78903 (RH)
78904 (LH)
Or possibly JUST the lock assemblies, the brackets look identical... I could just cut the existing "permanent" ones off them to leave just the bars.
