3FE FJ40 RTCustoms build.
Another thought...If we did move the PS pump to the DS - then it would be a shorter the run for the hoses. I do have the OEM 3FE pump...but Iam not married to the idea of using it, we could just toss on a chevy style pump in place of the smog pump...but then we would have some fab work..I just don't know if it worth the effort to??
I am using the stock 3FE pump and hard lines. The only modification is to high pressure line on the driverside. See pictures here:
https://forum.ih8mud.com/40-55-series-tech/189188-fj80-ps-pump-stock-ps.html
It does have a fan shroud but on the driver side of the rad. It has been cut off.
What about under the radiator? The 3FE fan is also lower. And, at least on mine, 2 fins of the fan come VERY close to the radiator mount. I may swap in the 2F fan also. It is an inch or so closer to the engine to give me more clearance. I loose the viscous coupling though.
For the compressor mount I am still looking at that. Probably just use the stock mount/frame, I don't have one laying around. But since there is an offset I will move the frame mounts to try and correct that on the next 3FE.
The frame mount on the passenger side is about 1-3/4 inches offset towards the driver side. Everthing is lined up front-back, just not side-side. I am thinking of cutting the 3FE compressor mount and somehow attaching it to the 2F mount. Maybe also cutting off the frame mount and bolting it back with a spacer. I am just hesitant to alter the frat in anyway. I may go back to a 2FE when this engine is kaputt.
The biggest problem is that without the 3FE compressor mount you loose the idler arm and belt tensioners. Bummer. I should have taken a picture of the original engine mount before I changed it. :doh:
I thought about that too. But you loose the tensioners. Also, I plan on mounting the Kazuma supercharger there and I need the space for a custom bracket. I will try and adapt the smog pump mount for a PS pump later. At that time I will convert the hard lines I have into a cooler.
SUPERCHARGER! IMO I don't think your going to need it. ask Alex he drove my 3FE 40 this am. The 3FE engine opens up behind a stick shift...I think it's a rocket, The Supercharger would be great....but Iam not sure you need it. But if you get one....then I'll have to get one. :D
Randy - the TB looks great!!!
That's it Mark. You're killing me. I'm going out to the garage.
My engine is still purdier than yours.
Well I will tell ya, that 3F EFI in the 40 ROCKS. PERIOD. Any faster and it'd be ridiculous. The thing doesn't handle well enough to need any more power, IMHO. It was prefect. I am going to do this no matter what. Only thing I didn't like was seating position and the shifter being a bit low.....
We were sourcing an engine before I even left Randy's driveway! By coincidence, my freshly listed 2F is (I think) spoken for and on it's way out the door.
Soon as it's gone I'm grabbing the newer engine and starting on the EFI 3F install.
Pappy: Not for long!:D
tlx4: Hope we meet up to compare notes
Alex e: Great talking with you and get that chassis rolling with the tub on it!!! We need to be driving not wrenching. :steer:
mmw68- Get coffee then call me.
Ooooh powdercoating! What parts?
Can I give you some of mine to get done? The seat rails and brackets, specifically?
Does it matter if there's paint on it?
I can come by around noon?
