- Thread starter
- #41
Gotcha. Usually stay around the meadowlands stadium if we make it into the city ill let you know.No worries. I'm booked in the city all week, so that's probably not going to work, but I do appreciate the offer.
First thing I would do is check the EFI temp sender. Make sure it specs out. Second is I would find another ecu and give it a try.
3rd you have sludge in your motor. It's going to cause the black oil until it's all gone. Seafoam can help over a long period of time.
On the cats. Get a shop vac or leaf blower and put the tube on one side of the cat and fee your hand at the exhaust tip. Do both cats flow the same? If so is the flow fairly close to what the leaf blower or vacuum is reading? Could mean a cat is clogged or you have a restriction in the muffler. Have you tested the EGR? Also look at wire harness going through top of motor. Does moving it cause any issues?
Lastly what are your compression numbers?
Even when my engine is cold I still get the "not enough power to get up a hill" syndrome. But sounds similar.Does your engine have a knock sensor or equivalent sensor?
The reason why I ask... The past few days I have been fighting with mine on my 97. Obviously mine’s a different engine and guys far more knowledgeable then myself have already weighed in, but my symptoms were similar. At startup/idle it sounded fine and power appeared normal, but halfway down the block (or as the engine warmed up) the power would start to diminish rapidly. Apparently the bad sensor told my engine to retard the timing and go into “limp” mode to protect the engine from potentially “knocking”. With the pedal floored I could barely get up the hill to my house. Anyway, each time I restarted the engine when it was cold, the power appeared normal at first, but would quickly degrade as the engine warmed up. Replacing my knock sensor has fixed the issue.
Anyway, perhaps this info leads to something helpful. Wish I knew this engine better. Either way, good luck figuring this out.
Could you post up a new check list of everything that has been checked and ruled out and another for everything that has been checked and or replaced.
Or eliminate the EGR system entirely.
SC truck from here on out thus no concerns with inspections. Yet I've discussed removing EGR system and everyone seems to have concerns with 1 how the ECU will react and 2 that the gains would be small compared to either my time spent or money spent at the shop.Will he have problems passing NC inspections though? If not, that's probably easiest (granted I don't know if the ECU would be unhappy).
Also, quick search on the 3FE shows there's a EGR modulator as well, that has a cotton filter that can get clogged. Advice: troubleshoot the entire EGR system and replace anything that is a wear item, including vacuum hoses.
But making sure that valve and modulator are working properly is something I've yet to look into, excellent advice. Thanks gents!
@DeeRex how did your ECU react when you did your desmog? No issues?
IIRC, there is a resistor hack you can do, similar to the 80s, that fools the ECU to thinking that the EGR is working properly, but it's been a long while.
Perhaps @jonheld has a few moments to provide thoughts on the points in post #48?
take the time you are spending on this and invest it in planning a 2uz swap... more power, more mileage, many more donor vehicles available. there is likely a good reason the 3fe was forgotten.
Just take the EGR out entirely if it is suspect at all.
Wont really give you a hp increase but it will run smoother and leave off another thing you wont have to worry about.
It didnt affect the ecu on mine at all. Cleans up the engine bay quite a bit also.
I think I got a small bump in mpg but it was so small that it would really be hard to accurately gauge but it did seem the light came on 10 miles later every time...
