Took some time to design and 3d print some replacement step nuts for the truck this past weekend. Also made a little install tool so the screwdriver wouldn't mark them up during the install. Shot some paint on them and installed.
| 58625E | CLIP(FOR REAR FLOOR MAT PLATE) | ||
| 90467-04017-03 | BLUISH GRAY, TRIM10 | 4 | $1.42 |
| 90467-04017-C0 | BLACK, TRIM1*, 4* | 4 | $1.46 |
| 90467-04017-E1 | OAK, TRIM4* | 4 | $1.42 |
| 90467-04020-03 | BLUISH GRAY, TRIM1* (04/1990 - 10/1995) | 4 | $1.50 |
| 90467-04020-E0 | OAK, TRIM4* (01/1995 - 10/1995) | 4 | $1.50 |
Not much cheaper but, easier
i started to turn some aluminum nuts in my lathe then it occurred to me that Mister T must have a reason for plastic. My guess is that if you stomp on a metal nut with enough force you deform the bolt , which would be hard to replace... so I ended up using delrin. My reasoning is it is better to strip or deform a plastic nut than deal with replacing the boltI hate these stupid plastic things. Has anybody found a metal option? If not I just may go with a threaded sleeve and a bolt/washer up top...
We need a thread on 3d printing designs (you could start the trend). I am working on a few things and I would be happy to post the files up for those who could use them.3d print some replacement step nuts
@NLXTACY sells extended in grey, black, and brown.Can you make an extended set? I have sound deadening and the stock length nut don’t reach the metal screws anymore?
Ordered. I poked around more and found them on Joey's site. Thanks all!@NLXTACY sells extended in grey, black, and brown.
80 Series Plastic Step Nut- Brown Extended
80 Series Plastic Step Nut- Brown Extended (PSN-4)absolute-wits-end.com
I also have some sound deadening. Had these screws for yrs.
