So I rebuilt an hl turbo and put the extended tip 11 blade 13t compressor on with an 11 blade turbine and bolted it up and expected to see a major difference. Instead I got a huge leak in the stock blowoff valve. I also remembered that I had not gasket matched the housing and gasket to the exhaust manifold when I switched it so I took it all off and blocked off the blowoff valve and ground to housing and gasket so it wouldn't interfere with the gas flow and excitedly bolted it back up a few days ago. Pretty stinkin cold here so wasn't actually fun. I usually love putting a new turbo on. I then took it for a drive like a giddy school girl. Much to my disappointment it runs about 50f hotter and runs slightly worse drive to boost pressure. Almost never gets better than 1:1 and occasionally runs worse.
I suspect that because I'm only running low boost (14lbs Max) that the turbine was actually quite fine flow wise with that before with the 12 blade. The extended tip 13t is also technically a larger compressor due to its smaller hub and extended tips so it will require more torque than the stock one. So I think I'm trying to do more with less which usually doesn't work out. I'll swap the 12blade turbine back on and see what the egts and pressure are like.
Pretty disappointing, but trial and error is finding success in a pile of mistakes. I'll try and not make a huge pile.
g
