.....but its a little hard to tell if the seal is perfect or not.................
It might be best to suck on a separate (cleaner & longer) bit of "clear-tube" (for hygeine reasons and to enable you to get in a more comfortable position).
.....Which reminds me of an Email Joe Egolf just sent me showing what happened to a cow that got its head stuck under the lowest rung in a fence (trying to get greener grass on the other side):
Then, using your mouth only, draw a vacuum and put your tongue against the end of the tube.
At this point, provided your diaphragm and chamber are air-tight, you should be be able to feel the vacuum trying to suck your tongue into the tubing. (Takes about 1 to 2 seconds to do!)
If that vacuum (against your tongue) disappears (when you stop sucking) ---- you know you have a problem.
Simple as that!
By the way - Based on how loose those screws were - You may have solved both problems now
(I've included a foto showing this)
