I need some help with a mild overheating problem.
Technical info:
Ian
Technical info:
- '75 40 with a 350 swap - purchased 1 month ago with the swap already done
- No idea of the year of the motor (haven't cleaned the area with the casting numbers yet).
- Stock radiator
- Fan is on the motor
- Holley carburetor, 4bbl.
- People have run 350s without heating issues
- The temperature gauge is functioning properly/reading correctly
- This thread won't deteriorate into a Stock vs. Swap bash fest
- When driving the temperature slowly climbs. If I have a long drive without a lot of stops, and a "coolish" day, the temperature will hang out at ~170. However, if I have stop and go driving (~3 minute wait at a light with ~5 minute driving cycles) it will climb to ~190. Prolonged stops cause the temp to climb over 200. I have ~45 minute drive home and by the time I arrive the temperature has been at 190 for a good 10 minutes.
- When the temperature hits ~190, the truck starts hesitating when applying the gas (vapor lock?).
- I've built a fan shroud for it as it came without one. This helped slow the temperature climb, but not halt it.
- I plan on replacing the water pump with a high flow, short rise pump
- I plan on replacing the thermostat with a 172 degree unit
- I plan on pulling the radiator and checking for obstructions
- I have a Flex-a-light Black Magic fan that I'm hoping to install if the short water pump nets me enough room
- Anything else that I should look at/consider?
- Can I use high pressure (1750 psi) sprayer to dislodge any sediment or blockage in the radiator?
- Should I look at trying to flush the block with the high pressure sprayer also (is this even possible without completely disassembling the motor)?
- What have others with 350s done for their cooling?
Ian
