350/carb engine temp?
Lodge Grass, Montana
Just back from running the 40 up from 6300' to 8200' and wondered what the normal temperature range on a 350 with a carb is -
My 60 runs about 180 degrees on a cool day but really can not take the heat - I bought the Hypertech Chip and 180 thermostat but she will still climb to 210 in the heat.
My 40 is new to me and seems to run between 160 - 180 degrees - with a spike to 200 when I was climbing/towing my trailer.
What is a post without a picture
mine hovers around 190 in spring /fall when i wheel or hot out i hit 210 215. no biggie. my dodge runs at 215 all the time. i think you r okay
temps sound fine to me...
a motor runs at is absolute peak performance immediately prior to blowing up :D running that fine line can be fun....lol
If you have cooling issues, a FlowKooler water pump did a nice job on my TBI 350 to keep temps more stable.
Thanks Wood -
I will look into that - the 60/TBI has a tough time cooling - putting a cowl induction hood on soon -
You know that fine line in your motorhome huh? :flipoff2:
lol...the Lemon didn't overheat...it did toss a valve thru the #3 piston tho....
IMO, cowl induction will do little/nothing...you will get equal improvement with a stock GM air cleaner and running the hose to the front of the vehicle.
Make sure your fan clutch is in good condition and that you have a properly designed fan shroud.
mine runs at 190 to 195 all the time. Haven't really towed with it thou.
woody said:
...and that you have a properly designed fan shroud.
Hey Woody, can you comment more on this?
I've heard a couple of different things like the fan blades should be halfway in/out of shroud. I've also heard the fan should be completly inside the shroud.
Or is your comment more that the fan shroud was built/designed for that engine/radiator/fan combo?
I got a sweet deal on a brand new AFI aluminum high flow water pump, so I'm going to swap that, have the stock radiator fixed, and get a better flex fan and shroud.
with my truck I run a clutch fan and a huge radiator no shroud, it works fine, but I don't know enough about these chevy motors
FoYoChe said:
Is the Taurus fan preferable to a mechanical fan and a good shroud?
Both have their place (i.e. water crossings and such) but to answer your question, no.
