I've searched and read hundreds of threads, over dozens of hours. Still having trouble getting my head around the 35" tire problem. It seems there is no way to make them work without cutting the rear fenders. Sure, there are the occasional few who say they don't rub with a 4" spring lift, but most of them admit they don't flex/wheel it hard enough to notice. SOA is better, but the general consensus seems to be that 35" tires require either cutting the fenders, or increasing the bumpstops to the point where you have so little up-travel as to make the efforts and expense not worth it.
I've seen hundreds of pictures and I see where they rub and where people cut, but here are my questions I still can't quite sort out:
1. Why do they rub?
It seems like 33x10.50 tires don't generally rub with a 4"/SOA lift. Is it the 12.50" width that is the killer with 35s? The extra height? Both?
2. Woud a narrower 35" tire tuck up inside and not rub, like the 33x10.50?
There is a good thread going on over in the Tire Tech forum about some new-ish tall/skinny options, such as the Kenda Klever R/T in a 35x10.50-17. Seems like that might work to give the height without the extra width of the typical 35x12.50.
1. Why do they rub?
