Pretty sure he made it thicker, not 'wider'.
I was just quoting the OP from around post 11 or12? I questioned that also. I see now that he did edit that: Kool!
First thing anyone should do on the 80s when there is cooling issues is to change out the fluid in the blue fan clutch per landtank instruction or buy the landtank one from @NLXTACY, even OEM fan clutch does NOT have proper amount and type of fluid for hot summer asreas.
Second if you have cooling issues(get a scagauge or ultragauge) then switch to aluminum radiotors like the guys in Arizona, if they don’t have their cooling system figured out then no one does. They wheel with AC on in AZ summer that’s well over 100 degrees.
Word of caution, now that you made the radiator thicker and if you do add 20 or 30k fluid in the clutch the tip of fan blades could make contact with the radiator, thoroughly test it at 4000 rpm with fan clutch fully locked before you go to middle of no where and slice your radiator open. Sometimes there are reasons people stick with tried and true.
I'm no expert on this, but the recore netted 4 cores, more fins and larger tubes. My understanding is that this provides more surface area for cooling. I agree though that going thicker doesn't necessarily give you better cooling. I think it really depends on several factors.
... Then maybe a Snorkel for cooler IAT. ...
OEM Aluminum has two rows for a reason. Air flow. Thicker cores flow air more slowly.My Ron Davis is 2 core, and my Liland is 3 core. Both are super efficient and cooling capacity is about the same IMO. I have no idea about 4 core...
Yes it will, as long as it's the 1fz engine, and it will work better than the brass core that is specced for the '93. The only apparent difference is the aluminum core.Would anyone know if these TYC 1918 radiators will fit into a 1993? Going to RockAuto I see the TYC 1918 is a 1995-1997 product. However, in the RockAuto 1993 radiators section there are items with "1918" in their names which makes me wonder if "1918" is a size or part number that would transfer. Any thoughts?
forum.ih8mud.com
Highly recommend getting a koyorad/oem radiator and skipping the TYC. Noticable quality differences too.
Build - ROTW- FirstToy
forum.ih8mud.com
so far excellent cooling with koyo, will see how summer goes.
I replaced an OEM with an all metal (brass and copper) used CSF, but I had it taken apart, cleaned and reassembled. The quality may not be the same as the factory (in fact, it's probably much better).Hey rad experts, we had an extreme cold snap at Christmas. -44 Celsius and I’ve been doing coolant since, just found the leak between the core and upper tank on my oem rad. I think I would prefer an all metal rad, and updates and recommendations? It looks like liland is out of stock, don’t want to spend for the Ron Davis unless I have to. Csf? Others?
My old rad was Koyo but it wasn't cooling well- I got it new in 2012.James - are you running the two core Koyo radiator with your supercharger? I'm running the same with the turbo and she can't keep up, not even close during the summers. I tend to hover around 220deg F when I'm on boost.
Radiators are a consumable product. They lose efficiency over time, due to one or more factors- dirt outside, dirt/oxide/electrolysis/other deposits inside. While I agree that the TYC probably is not the highest quality replacement radiator, I would argue that it has been demonstrated to be the best cooling radiator available, and for the price it makes sense to replace it more often than other brands to maintain the excellent cooling properties in extreme conditions. You can spend a grand on a rad and maybe it will not fail structurally for several decades, but after only a few years it won't be performing as well as it did when new. Especially in offroad conditions.My old rad was Koyo but it wasn't cooling well- I got it new in 2012.
Makes me wonder if I got a bootleg Koyo- remember back in the day people were talking about that?
New Koyo ran noticeably cooler and never above 190 on a recent trip (under same conditions). Will see how it goes this summer.
The lack of quality of the TYC just isn't worth it, imo. Trips are valuable in time and planning.
Can't waste either on a failure of cheap quality if I can help it.
I always gauge the value by the time lost if it fails. IMO, Koyo is more than quadruple the value of a tyc.
If changing from OEM, I would go Ron Davis or a good all metal unit.
If you're in extreme conditions, why wouldn't you just get a Koyo at bare minimum and have quality build and cooling. It's not even much more than a tyc.Radiators are a consumable product. They lose efficiency over time, due to one or more factors- dirt outside, dirt/oxide/electrolysis/other deposits inside. While I agree that the TYC probably is not the highest quality replacement radiator, I would argue that it has been demonstrated to be the best cooling radiator available, and for the price it makes sense to replace it more often than other brands to maintain the excellent cooling properties in extreme conditions. You can spend a grand on a rad and maybe it will not fail structurally for several decades, but after only a few years it won't be performing as well as it did when new. Especially in offroad conditions.
Because the Koyo doesn't cool as well as the TYC. I've had both, and seen the results when multiple 80's were tested with both. Also, I have yet to have a TYC fail structurally.If you're in extreme conditions, why wouldn't you just get a Koyo at bare minimum and have quality build and cooling. It's not even much more than a tyc.
I bought a tyc. Nothing but a waste of time and money. Time far more valuable, so i'll go for a few bucks more and get quality.
