2fc ???? Hmmmm
Bonham Tx.
Doing an engine swap, pulled the old motor out, noticed a strange looking Exhaust manifold......Emmision tag states 2FC, and that the vehicle complies with California emmisions for 1976, take a look...... :confused: :confused:
I have one of those thermonuclear reactor suckers. They suck. They get real hot, they crack and the studs get all messed up. Mine has 2 cracks that I had to braze up. I'm stuck with it too, because it needs to pass a smog check as long as it stays in the People's Republic of California.
They are the first generation of thermal after burners before catalysts. They are suposed to reduce CO and HC, but they aren't very effective as the smog specs are no different that for the federal model.
BMW used those on early-mid '70's sixes and they cracked heads...bad. Thermal reactors, I think they were called. They changed the waterjacket in the head design and continued to use them for a while.
Sorry you have one PH, but glad it cracked itself instead.
Ed
My '78 eventually got about 6 cracks in it, so I replaced it with a Federal manifold and head pipe.
Pin_Head, YOU HAVE A CHOICE. The Downey header is smog legal in ALL 50 STATES! :bounce:
The Cali reactor manifold is the s***tiest, most power robbing thing Toyota ever put on a cruiser, and I wouldn't leave on even on a restoration rig.
I may have been a little over dramatic there in my continuing grief over the repeal of the 30 year rolling exemption. What were those idiots in Sacratomato thinking? Making sure 30 year old cars pass smog tests is going to fix the air quality issues in the LA basin? People fart more HC than 30 year old cars put out. It's not like the state doesn't have any significant problems that they should be spending their time on. This year banning "pet cloning" is at the top of their legislative agenda instead of fixing the real problems.
I could also use a federal model manifold, but I would have to change out the EGR tube and the head pipe no matter what. The thermonuclear reactor cooks the hell out of the carb, even with a cooling fan. The power issue doesn't bother me because I used to drive VWs.
Careful who you say that to. Next thing you know they'll be passing emission laws for us farting folk.
FJ55 header w/ EGR?
I got one of those things on my FJ55. It came to me cracked, and after almost a year of searching I found a decent replacement for it; it's just a matter of time before it cracks too, I suppose. Or my intake... I'm not sure if CA smog inspectors are clever enough to tell if you have a CA or Federal ex. manifold on. In fact, I was told by a helpful person (no, really!) at the B.A.R. (governing body for the smog-nazis, so to speak) that I could "most likely" get away with that conversion. He also said a "50-state legal" header is also acceptable, as long as my EGR is hooked up and functioning.
I agree with the gripes about 30-year old cars passing smog inspections: I have no problem with having to pass an emissions "sniff" test. It's when you have to retain all that nearly useless junk that actually makes the rig run worse that makes me mad.
Hijack attempt: is anyone running a header on a FJ55 AND a functional EGR system? I understand there are clearance issues with the steering box.
Nial
Charlie, I did exactly that. Replaced the manifold, head pipe, and EGR pipe. Bought the parts from Mark (65swb45). Got any left, Mark? Had the intake manifold crack welded up while I was at it. Solved a lot of problems. I'm no longer in CA, but I doubt that your average smog inspector would notice the change from CA to Federal.
By the way, Butch, that's a damned nice looking 2F you pulled. There's gotta be a bunch of people that would love to have that engine.
Todd Bull
Todd Bull
They are still available and listed on the website. Suppose I'll be talking to Pin_Head about this and other interesting trivia at the TORC show next week. ;)
