2f with flat tops
:crybaby: Damn my empty cambered head. How much JB weld do I need to fix it :hillbilly: thank you for the info guys this ENG stuff is new to me.
Beware when you go head hunting.. the later 81 and newer are prone to crack.. I have a pile to prove it.. most between #2&3 cyl Obtain from a reputable source...
might be easier to get some dome top pistons...
That combination has higher compression std than the flat/closed combination.
If it were mine.. that's the path I would take.. I no likey later model heads...
It's the opposite in the US market-
the open/dome combo is 7.8:1
Closed/flat is 8.3:1
:cheers:
how much dose it need to be shaved? that sounds like the cheapest way to go and have a stronger head that will be less likely to crack.
I'd take the full .100 inches
Mark...
shaving the head. Will this effect my push rods and rockers.
The saved head sounds good. Is this better then the 81 style head? pros @ cons. The pistons are marked 75mm do they make domes in that size? The pistons would be hard for me to do as I do not have the space to work on my pig. My land lord dose not have a cruiser so he dose not under stand. thank you aging
John, I shaved the open chambered 2F head I got from cruiserbrett and put it on my FJ60, remember? Seems to have worked out fine.
It's still not my first choice for YOUR engine. I am in the same boat with Ian as far as thinking that you just need to put some good hours on the engine to break it in. Some break ins go fast, some don't. While there are general rules, there are also exceptions. And I have seen several of them.
And now that you've seen how bad the pistons were wobbling inside your old block, [yes, WOBBLING!:eek: ]you at least have the satisfaction that 'going back' wasn't ever really a good option.
Best
Mark A.
After pondering the cut .100 thing..I run a virgin head past 3 machine shops in my area.. none of which were willing to do the task...after all the in-depth measuring and discussion there are some grey areas where the resulting integrity would be a risk... so if this was my scenario, this would not be a option.....
John likes driving to pismo. Mark I will swing by today with a large coke:) . pistons aren't suppose to wobble :confused:
As Jim has already pointed out OEM spec .100 a max allowable. I've taken this much many times. None of the machine shops I use have a problem with it and none of the rigs I have done it on have had a problem from it.
Mark...
