I have a 75 2f with flat top pistons and open camber head can this cause a poor idle the carb was just rebilt the ENG has about 100 miles
The vac reads 10 the compression 118 I got the rebuilt ENG for 500$. oh it all so has a RV cam
A vac. reading of 10 or lower( steady? ) is a indication of" LOW" compression.. 118psi ..is 28psi above the" DEAD ZONE" too close for comfort.. as for a '74 "F-and-a-half" goes? they are few and far between... I got one and I'm gonna keep it..
But they are availableNot Unobtainium.
Ed
I will stat looking for one.If the low vacuum reading is due to low compression, it can only be bad cylinder sealing, which means cylinder wear, assuming you actually have new rings - pray that is not the case - or bad valve sealing. In the first, you should have obvious blow-by, in the second, obvious running problems. Highly unlikely, it seems to me, though, that you would have the same compression in every cylinder since all would wear differently. It will defintely not be due to the low compression ratio since vacuum is primarily a function of intake system integrity, i.e., sealing, as Pin stated. Aircraft recips have very low compression ratios but pull 30 hg. with no problems. Usually, low vacuum is due to timing and valve issues, but it could also be a plugged exhaust, among other things. Low compression in every cylinder could mean the timing gears or distributor are off one tooth, so if the distirbutor is jacked all off to one side of the timing range, suspect that. If that is the case, though, it probably won't drive worth a sh*t, if at all. Very likely, as is usually the case, it is due to a combination of factors. Low engine vacuum means low venturi vacuum means low fuel supply at idle. Try seeing what the vacuum does at all engine speeds as a way to narrow down the areas of concern, after first checking timing, etc., to be sure that stuff is OK. There are numerous sites on the web that provide good detail on the readings obtained.
