2F Whisperers Needed
Costa Mesa, CA
I'm stumped.
1975 2F that has been rebuilt by a PO. Strong compression numbers - 156-170. Downey headers, Petronix ignition, less than 100 miles on a carb rebuild by Mark. As it is a '75, no smog equipment. Have owned it for a year. Things I have done to the engine in addition to having Mark do the rebuild - New plugs, plugwires, coil (Petronix), rotor, rotorcap, fuel filter (replaced twice, including just today), air filter, voltage regulator (OEM). Note, I asked Mark about any material in the carb when he did the rebuild and there was very little.
What's happening - Fires right up, smooth, even idle, revs smoothly. For the first 10-15 minutes it runs beautifully with plenty of power - like it has up until yesterday. Now, once it passes that 10-15 minutes and is fully warmed up, it suddenly won't run with any load on it. It will idle (a little lumpy), but try to move and it wants to die. Pulsing the gas pedal will get the revs up a bit, but barely enough to move forward.
I changed the fuel filter and swapped in a known good coil and it behaved the same - fine for 10-15 minutes and then it starts having trouble. I'm trying to figure what it could be that only causes a problem once the engine has warmed and after it has worked normally for those first 10-15 minutes.
Open to suggestions. I'd like to get it working properly to be able to take part when the FJ40 Cross Country Expedition comes through SoCal.
Thanks
What pressure is the fuel pump putting out, both cold and when it starts acting up?
Forgot to mention - New OEM fuel pump installed about 100 miles ago. The old one was working fine, but given the age of the vehicle and ethanol fuel, I did as preventative maintenance. I could not tell you what the fuel pressure it that it is putting out. At idle, I can see the fuel moving smoothing through the filter.
Is the fuel level in the sight glass at the right level when it starts to run like crap?
I have yet to check that. Will have a look tomorrow. Logically, I can't figure our why the fuel system would alter itself after running fine. Pump and carb are both mechanical. But stranger things have happened, I guess.
I just dealt with a similar situation, after about 15 minutes of driving my rig would die, no fuel.
Found crap in my fuel tank.
OP, it's a big pain in the butt, but this is where I'd go next. Drop the tank, clean it out (radiator shop) and new rubber fuel lines. Check out POR15 (or others) for fuel tank recondition products. Btw, deteriorated rubber fuel lines can cause similar symptoms.
UPDATE: Fired it up today and let it idle while I washed it - about 15-20 minutes. Idled smooth and got to operating temp. Proceeded to drive it around the empty light industrial area streets for another 15 minutes, going well into the rev range through gears 1-3. Runs perfectly. I hope it was just some crud that got passed through. Sight glass was at halfway mark or perhaps slightly higher.
When I replaced the sending unit 6 months ago (an effort to get the gauge to read more accurately - worked only a bit better), the tank was clean. Also, as mentioned, Mark said the carb was clear except for a small trace of 'rust dust'. Sounds like potentially a bad tank of gas. The rubber hoses had been replaced by the PO, but in CA, most of the fuel to be had is ethanol mixed, so probably worth changing again. I'm pretty well set on replacing the tank with a larger one offered by Cruiser Brothers, as I would rather do this than hang jerry cans on the back. Just need to decide if I go with the larger tank under the seat or under the vehicle.
Sounds like crud or a tank vent issue. Crud gets sucked up into filter or tank pickup. Let is sit and crud settles and car runs fine....until it gets sucked up again. I remember a post a while back where someone found something crazy in the tank like a spoon or pencil that was causing problems. Maybe a tank cleaning and new filter are in the future.
.02
The hard fuel lines that go from fuel pump up to the carburetor are also sometimes flaking rust into the fuel supply. There’s a thread on here Somewhere where the person doing the rebuild, thoroughly cleaned all the hard lines as well as the rubber lines, with thin bristle brushes, washing lots of rust particles into the bucket
Beats discovering this stuff on the trail
Hth
I'm stumped.
Thanks
Have you checked the timing at idle when hot? Or maybe the carb is to hot boiling over ? It could be a air leak at the base of the carb? Ck and see of the air pump is working it needs to be there to keep the exhaust valves cool.
