2F timing gears in 3FE?
United States of America
Hello everyone, sorry if this has been posted previously, I couldn't find anything similar searching.
I'm in the middle of a 3FE rebuild, but can't source a composite cam gear for less than $200. I already had a brand new set of steel 2F timing gears, would I be able to use them in my 3FE? I can't find a difference between the two besides the composition, and since I already have them I would like to use them. Thoughts? TIA.
I have read that the cam gear was changed to make it quieter, and using the older metal gear is an upgrade in reliability.
^^^ Agree.
That's good to hear. 2/3 of the composite gears I had were completely trashed, so I'm already wary about their durability. If it's an upgrade to switch to steel, I'l definitely do it. I appreciate the help, thanks!
Can you still source these timing gears? If so where can I find them. I'm also in the middle of a rebuild. I was also trying to figure out if the 2f rv cam is compatible with the 3fe. Looking to make more power so I'm boring it and upping the compression while I'm in there. Thanks ahead of time!
Read away:
Camshaft
