2F Seized today while starting...
A couple weeks ago I bought an FJ60 from a friend of mine who had just changed the head gasket on the 2F (207k miles). It was running just fine, I was working on getting it to pass CA smog (replaced cat this morning). It's had a slow oil leak at the plug, but I checked it before driving, it was about 3/4qt low, still above the "low" mark. I drove to O'reillys to get new oil plug gaskets and to warm up the new cat. In my driveway I killed the engine, then figured I'd see how it starts when warm (oil pressure was fine, temp was normal, everything seemed totally good except the oil leak). I cranked it once and it turned fine but didn't start.
I tried cranked it a second time and immediately (without spinning at all)... "THUNK"! And that was it. Every time now, it's just "thunk".
Put my jump start on-- still "thunk"
Checked oil again-- still above "low" line.
I pulled out all the spark plugs-- still "thunk".
I put it in 4th and tried to roll it-- "thunk" all locked up.
I pulled off the flywheel cover. Nothing looks weird.
I took a video of the starter/flywheel when starting. Starter pops out and engages the flywheel, then "thunk".
I took off the valve cover-- everything looks normal there.
Before I pull off the oil pan and start thinking about bent rods, stuck pistons or thrashed bearings, does anybody know of any common problems that might cause this? Flywheel getting caught on something? Distributor engaged funny? Parts that could shake loose somewhere and jam up your stuff? Anything easy?
It just seems really, really weird to me that it would seize like this... How could I have damaged the bottom end while nothing was even moving or anything!?
Yes I realize im bumping this thread from 7 years ago. Im having the E
Yes I realize im bumping this thread from 7 years ago. I am having the EXACT same problem....what ended up being the fix?
Verify if the engine can rotate 360°.
Remove all the spark plugs and then you should be able to easily slowly rotate the engine by hand by just turning one of the pulley belts.
If you can rotate it 360° by hand then it’s definitely not seized.
The prime suspect would be the starter and or the starter wiring connections.
