Take a flash light and look down in the bottom of the carb and see if the throttle plates are closed? then slowly step on the accelerator pedal to see only the primary throttle plate is opening? The secondary shouldn't open unless it's nearing WOT. The secondary may be vacuum operated or a secondary linkage that kicks it open. Anyway it should be closed most of the time. The throttle plates are screwed to the rod that goes along the bottom and comes out the front. Make sure they are not loose or flopping around. Also actuate the throttle linkage at the back of the carb with the vehicle off and see that fuel squirts down into the venturi...and make sure its' not dribbling excess fuel after you let go of the linkage. Also make sure the fuel is 1/2 way up in the sight glass.
