2F Aisan Carb Help
Sebec, Maine
In a bit of a bind here, my only means of transportation is my 78 FJ40. I bought a new 2F repro carb which is defective but have a 77 2F Aisan that needs cleaning and a kit, which I have.
Can I modify the Aisan carb to run on a supply only and plug the return line at the carb? I had a Weber then the repro that only required a supply only. Will I have to install a return to run the OEM Aisan?
Thanks for any help
Yes.
The OEM setup has a return line in the system somewhere. Either at the carb or at the pump (later style)
Matt
None of the pre-73 Landcruisers had a return line. And they were no more or less prone to fuel pressure issues.
Matt
Thanks for the clarification Mark!
What's the best way to clean a carb?
COMPLETELY disassemble it. ;)
The one thing you don’t take out is the one that will bite you in the arse.
BTW, people are slowly catching on to the idea of putting some coin in my PP for consultation privileges. The search button is handy, but I have a reputation for being more understandable.
Joe, I buy the gallon containers of carb dip from the local auto parts stores to dip the parts in. Just don’t let it sit in there for like a week. 4-8 hours should do the trick. Then I use compressed air and spray can carb cleaner.
Jeff, I was wondering about soda blasting and ultrasonic cleaning, but the later is too expensive for me, baking soda doesn't cost much, I guess I'll have to try Berrymans.
Have you ever thought about a "Mark's Off Road" membership?
I'm about to rebuild the carb on my '77 FJ-40, and am enjoying this thread. I watched a mechanic do a carb rebuild on the 2F on my (derelict) FJ-60, which was helpful, but now I wonder if I'm in over my head?
Just dip in overnight in Berryman’s Chemtool. Personally, I never remove the throttle plate from the shaft to dip the carb as it involves unstaking the screws and installing new screws and staking them. I only do this if new shaft bushings are needed. I also only remove one end of a linkage arm because it makes reassembly obvious; particularly helpful if this is your first time with the carb.
That's what my donor carburetor is, a 77 FJ40 to go on my 78. I recently watched a YouTube set of videos made in 2011 by Pin_Head about rebuilding a Aisan Carburetor; and it gave me lots of inspiration and confidence that I can do this. If you take your time and have places ready for small parts, take pictures if needed, plus there are many good people here on Mud to give you help. Go for it!
I'll try Berrymans. Is there a difference between Chem Tool and Chem Dip?
