- Thread starter
- #381
More patches.
Thanks! I use several tools. I will use the plasma cutter for larger cuts, the grinder often and a small bench shear too. Sometimes I will use the hand held tin snips.Amazing workmanship. What tools are you using to cut out the new sheet metal panels? Thanks.
That has to feel great to start putting things back together!
That looks like a very difficult repair.This is the most odd part on the vehicle. It attaches to the bottom of the rear apron. The D-pillar is sandwiched in between the apron and this part, then the quarter corner attaches to the bottom of this piece. I need to accurately install it on the new, reproduction apron. First, I need to remove all the old pieces spot welded to it and hop that its good enough to reuse. In the picture with the vice grip, that is precisely where it attaches.
View attachment 4160279View attachment 4160280View attachment 4160281View attachment 4160282
105 inside?!?Looks good. The two lines I ran through the bead roller look pretty accurate. All the bends in the correct locations. I will hopefully get the other side done tomorrow. Its 105 degrees in the shop right now.
View attachment 4164806View attachment 4164808View attachment 4164810
Haha! That last paragraph! Thanks you for letting everyone know exactly what I am truly dealing with.I love reading this thread and seeing back to back rust/corrosion photos....followed immediately by shiny new metal looking perfect.
It's like you have a metal magic wand that you just wave and *poof* new metal appears, looking great
I really enjoy skipping over the hours in between of measuring, cutting, grinding, bending, fiddling, welding, grinding, hammering, cursing, doing over, throwing tools against the wall, questioning my life choices, etc,
even when it is you doing it
lol
