2024 GX/Prado Release and Discussion
Status
Not open for further replies.
IForce Max only engine
1.87kw battery
1958 Base w Round Headlights>Land Cruiser>First Edition (5000 production run)
Std rear diff lock
31.5 inch tires on base model
32.6 inch on other trims
Sway disconnect top two trims
6000lbs towing std trailer brake control
Base model has lame skidplates. 8.7 inch ground clearance
Very high cargo floor, no 3rd row (conflicting info on 3rd row option.)
"Woolish" fabric in base model
2400w inverter
Base starts mid $50's Toyota officially lost their mind.
At least the Sombrero logo is gone.
Meh. I still like the GX better, and if the LC only comes in a T4, then I'm holding on to my GX deposit.
you guys see those blacked out vehicles in the back?
Back left is the mini cruiser
the one on the right looks like a cross over
a cross over LC?
Ah, I think you meant this picture.
The rear left model looks similar to the concept compact cruiser EV they revealed not so long ago:
The rear right one I can't identify. It kinda looks like the concept BZ5X:
guys check out some of the early design sketchs
man if only it had barn doors..wow
They still refer to it as light duty?
It seems there will be two different 4WD systems (depending on trim). One does not have center diff-lock. I would imagine it would lock automatically in 4lo?
Version without center diff-lock:
Version with center diff-lock:
Status
