Build 2018 Premium 460 build
Dude, I’m loving these outdoors pics. Really motivates me to finish not only my 460 overlander but the 470 too. :D
As the Cable Guy says, "Get-er done!"
Those puddle/undercarriage lights look very functional, are they?
I really like them. I don't care for headlamps so I can run these versus a headlamp. Inexpensive Wurtons off Amazon, somewhere in build thread.
Look at #344 for full details of Wurton installation.
Preparing for a trip to CO/UT we wanted a proper shower space that didn't require a tent set up thing. The Quick Pitch En Suite is the original En Suite made in South Africa and available from Quick Pitch North America.
I am currently working on fabricating brackets so I can install it exactly where I want it, so it doesn't interfere with other items located on the roof rack.
Stand by for more bracket pics and final build installation.
Pretty slick if it all folds down to a small enough package! Is it also your potty-privy?
Anything to prevent breezes or a wind from blowing that curtain on the person inside, and then sticking to them as they're trying soap or rinse off?
You can peg the bottom of the curtain out, two would be plenty unless its real blustery. Guess I need to post the gusseted brackets. I have 2" square aluminum tube on order, need to space the whole thing away from the vehicle. The straps can also be adjusted for height of the curtain.
  • Like
Reactions: r2m
Completed my En Suite brackets. My initial designed worked but I needed to space the whole assembly out so I ordered some 2"x 2" square tube aluminum as a spacer. The GX is bulbous and I could actually use more spacing but then you run into sticking it way out in the wind and tree branches. I sprayed the brackets with Krylon but when I send my new front bumper in for powder coating these will get blasted and powder coated.
Mounted the En Suite up added a rubber pad under each outboard attachment point to mitigate squeaking. One of my scene lights lines up and will work for night doody operations.
Night light.
This turned out well and won't interfere with my shovel access or scene light when the En Suite isn't deployed.
Field test will be conducted this weekend, main concerns are wind noise at freeway speeds and tree/brush contact on the trail.
As the parts have trickled in for front, rear lockers, gears and day 80 on the Victory front bumper. I have had a fairly busy summer.
This last weekend we went up to Bonners Ferry ID for a small overland rally and conducted a bit of training Saturday and Sunday.
Saturday consisted of Hi Lift Jack, powered winching and basic trail drive. Sunday was recovery equipment review and tire repair. Titan Truck equipment in Spokane sponsored the training and we were happy to conduct it! Jeep, Truck & SUV Accessories & Equipment | Titan Truck Equipment - https://www.titantruck.com/
Man, I wish I was there! Looks like fun. Cannot wait for us to move up there!!
It's beautiful for sure! We will be in Sandpoint in two weeks for another event.
Darn job... Gets in the way of everything!!!
More like, darn 2,000mi that get in the way. Haha. I cannot wait to get the hell outta here and move to north ID.
  • Like
Reactions: r2m
The elk should be bugling by that weekend!!!
Shortages everywhere, just received an email from Nitro Gear. Depending on what gear set you want you need to book now for 4:88s in late December or 4:56 for late January or early February.
:frown:o_O:mad:
  • Wow
Reactions: r2m
