Build 2018 GCC Spec 79 Series 1HD-FTE + H152 - The Camel
Very nice package indeed
Can you share any specs on the shocks?
Rod dia', piston dia' , travel etc.
Did they get in any Kings specific valving or did you ask for your specific valving ?
Sorry to hear about the long lead time, fox are very similar nowadays and many European vendors also.
Very nice and super clean build Sir.
I can really appreciate the bumper after having mostly rebuilt mine from OEM parts. Really cool that you kept the look of the original.
2.5" dia, 2" lift (roughly 10" travel), adjusters, front revalved for heavy FTE, winch bumper, ect. Nothing to fancy, it may be used as a work truck! :steer:
Cheers
Cheers
Very high end for a work truck in my part of the world...:clap:
I would expect a great ride with minimal to none heatup issues with these, even at very high ambient temp's and heavy loads.
Does King have good service and available spare parts at your area?
I would be very much interested to see photos of the vehicle fitted, with
A written description log of the ride quality through your eyes.
I love these things, don't have a lot of available reading material in this field...:cheers:
Got this today.
That is one sexy top mount! 🥰🤙
Cheers
Thats a very cool looking top mount - one of the better ones Ive seen
Dont wanna hijack your thread - but just for interests sake.
on my FTE i went with the front mount
The problem is the '07+ (wide nose) 70 series wasn't offered with a 1HD-FT(E).
Therefore, nothing off-the-shelf fits like the PDI kit.
The original plan was to run the top mount and a front mount. As @TonyP mentioned, there is no front mount kit for a wide nose FTE 70 series. There was some consideration of doing something custom on the front but I told @SNLC to just do the top mount for now.
The CC top mount needed just a bit of customizing on the mounts and brackets.
Still got some work to do on the ducting. Wiring is just about done, should be doing a test power up real soon.
Cheers
OEM double fuel filters fitted.
The ARB compressor for OBA dropped in here like Toyota meant for it to happen. I don’t recall what was mounted here originally maybe ABS pump. The compressor though required no brackets/mounts made and no holes drilled.
We built our own pass through for harnesses on the firewall.
Cheers
We carved up the hood a bit in order to fit our in house built ducting.
Money shots on the FTE. 😆
Cheers
Problems at full lock, even with longer radius arms.
Moving front axle forward.
After, full stuff
Front bumper tire edge trimmed and rewelded.
Cheers
Aux fuel tank finished up. I don’t recall if I mentioned it before but this is a 100-series LRA tank. We custom fitted it and also had to move the filler neck to the RHS.
Beefy custom build skid plate made for the tcase.
Cheers
