Taco2Cruiser
Crazy American Off Road
@TXSunDevil, @HRTROB, @TonyP
the DIY site didn't have much.
Do you have any other information on the AC? The radio looks fairly easy it is the climate control that concerns me.
That is very interesting. Notice that it shows without the multi-display the AC controller does not run on a CAN it runs on a LIN communication line.AC System breakdown for manual and automatic
I would like my display just to stay on Radio controls all the time. The navigation screen keeps popping up after a minute.
You can deselect that feature, I don't recall exactly where, found it by accident.
I agree. Tomorrow I will go through the EWD and check all discrepancies that may arise when removing the Multidisplay. It looks only to effect plugs F27,F28,F29,F30,F31 and F37. It appears the AC amplifiers are the same and just the controllers will change. Maybe we can confirm with @HRTROBYeah rear entertainment is a whole 'nother bag of worms. I would think, in regards to Bluetooth and rear entertainment, the ability to switch to a fully functional double din unit would be worth any downside of losing the control of the rear screens from the front. You can always use the RCAs and the remote to still use the roof screen. Plus, bluetooth comes with every new aftermarket headunit anyways.
It'll always show the map on the left but the right side of the screen can permanently show the radio/audio.
Follow the yellow wire off of your AC control assembly. it will hit a connector in the dash and come out on the other side yellow also. Follow that until it hits a black box. That should be the AC amplifier. Also does your clock show the inside temperature at all?I'll try to check today. Any idea where the AC amplifier is located?
Supposedly the F to C is built into the dash cluster. Was not an issue with the 2006. I see what you are saying about the markings on the clock. When I read the descriptions the only difference is the DVD?I noticed while searching around some climate controls have green, some have blue background. Interesting.
Also, hopefully plugging it in will automatically switch it to Fahrenheit but I doubt it. Might need to find a way to switch it (in old BMWs this is easy), or source a control unit from a country that uses F.
And that clock panel is definitely different. The "Security" LED is on the Multi-display trim and the dual zone temps are up there with a Navi unit. Guess we'll have to add that in to the shopping cart too.
That makes total sense. My Lexus changed time on the screen for the clock. The clock looks plug and play but the correct clock must be used I think so you could set the time.I believe that clock PDF is the only one I saw in my FSM. Might be plug and play since it gets the time settings via CAN on the multi-display 200s. It looks like that clock assembly has buttons to change the time whereas you change the time in the MFD in a Navi equip'd 200. Unless I'm mis-remembering.
@HRTROB any chance your dash is still open and you can get a photo of the clock part number? Thank you for your help
