2008-2009 LC Navigation Delete
Close-up of the climate control connector
Thank you for posting that. That appears to be the F10 A/C Control Assembly.
That shows to connect to the amplifier part 88650-60E32 possibly? Here is a photo of where that should be and the connectors. Did you happen to see the amplifier? The parts diagram doesn't show exactly where it is but the EWD shows this. On my 02 the AC amplifier was attached to the navigation screen. I think that is why my original photo shows so many plugs. The photo I posted from Ebay has the AC amp, radio and navigation plugs. On yours the amp is probably separate.
I just went through the entire EWD. It looks like there has to be something that taps into the CAN system. It sends the signal to the AC amplifier. You can see in the EWD schematic I posted the CANH and CANL come off of the Multi-Display. I am curious what your vehicle has the sends the signal to the CAN system. You have the F16 and F17 temp controls also. The parts breakdown I am find online are not real good.
Is the F28, F31 multi-display the unit above the radio? On mine it is just a clock and anti-theft light. The CAN connection could be for the outside temp, anti-theft or passenger airbag?
It is hard to tell on the schematic. It could be but the clock is shown at g1 w/o multi display. They do not show an option for a clock with multi display.
I guess it is possible the clock could come with a multi-display but I feel the multi display is the nav screen. The way this shows to be wired without the CAN connection there is no way to send the temperature needs to the AC amplifier. The AC controller has to turn the fan and system off and on. Here are the F28 and F31 connections along with their location.
I just noticed your hazard light button and those buttons to the left and right of the hazard symbol. Are those Toyota buttons?
Nope only the hazard light button is part of the car. The other buttons are part of the radio
Factory stereo?
Nope, it's an aftermarket Android stereo. My factory radio was a standard Toyota 200mm wide 2 DIN. The radio plugs are the standard 1987-up Toyota 10 and 6 pin radio connectors.
I think you're right, it looks like the multi-display unit is the nav screen.
Wow. Ok I guess I have never one like that. Looks like buttons wrap around hazard light. Thanks for your help. I am going to keep searching parts diagrams for what part your style vehicle is used to transmit the call for heating or cooling through the CAN.
Wanted to leave this here for reference. This is the AC control that @HRTROB has in his vehicle. These are the stereo brackets, left and right plus screws to install into the frame. Then the Toyota center trim piece that covers the double DIN. This is a beta work in progress so don't buy them now.
I believe there will be one more piece missing. According to the FSM there has to be a piece that ties info into the CAN system. This provides the signal to turn on the heat or the cool. The FSM shows the multiplex. I am unable to find a EWD for the non-US versions and the parts diagrams I am finding online are not much help..
Wanted to leave this here for reference. This is the AC control that @HRTROB has in his vehicle. These are the stereo brackets, left and right plus screws to install into the frame. Then the Toyota center trim piece that covers the double DIN. This is a beta work in progress so don't buy them now. View attachment 1622619
I'll look through my FSM tonight. It covers non-USDM 200s.
Look for the part in the top picture on Post #22. Should be F31 and F28. They call it the multi-display but I think the non-US have some type of box to get the signal to the AC amplifier.
Let me know if you need more or something different.
Does your book give a part # or anything else for this F63? It looks like the other part instead of the multi display. The EWD I have is for a 2009 but it only shows the multi display option
Does your book give a part # or anything else for this F63? It looks like the other part instead of the multi display. The EWD I have is for a 2009 but it only shows the multi display option View attachment 1622784
Here's some more that might help. I can't find specific part numbers in my FSM. This site probably has it somewhere
ToyoDIY.com
ToyoDIY.com
the DIY site didn't have much.
Do you have any other information on the AC? The radio looks fairly easy it is the climate control that concerns me.
