- Joined
- Jan 18, 2007
- Threads
- 37
- Messages
- 604
- Thread starter
- #221
Ok, we are good to go. ALignment done but not as exact as I wanted, I didn't know they didn't know what they were dealing with. I Have trained them before on how the 333 Fab lower CA bolts work and how to adjust the SPC uca's IF needed.
Drive is good and firm, have a few "offroad" trips coming up for a run down.
Install notes are the same as everyone's with the exception of the polyurethane bushings not allowing the suggested flex to align the holes. With rubber bushings this would probably be no issues.
Side note, make sure your ITR are tight, because the gx460 racks DO NOT have the little metal washer that has the bendable ears to keep the ITR nut in place. I accidently loosened my DS while adjusting the alignment in the driveway. Also my ITR tool that slides over the end and clamp down wasn't big enough to go over the gx460 ITR head. The flats measure 42mm.
Other than that, nothing different...
