Build 2007 GX470 Build Thread
This weekend I played the Let's learn bead locks the hard way. Keep in mind the manufacturer says OFFROAD USE only and 25psi max.
I find it at the moment kind of like marine engines and equipment, a mix of black magic and luck. When I installed the BLs I lost some bolts, as in the broken at the 3/4 line, thought nothing of it because this company had some issues a few years bag with bad hardware. I likened it to the issues Trail gear had with hub studs on the 80 axle a few years ago. Anyway, I replaced the broken one with a new one from Tractor Supply and went on with my life. I Had this nagging feeling though that the breakage had something to do with the bolt heads not sitting flush, there was the slightest bit of daylight under them..... I sent photos of that and what looked to be no coning (deflection) of the BL Ring to them and we agreed that it looked ok.
A few easy camp/ wheel trips and a few more bolts here and there. Fast forward to this past weekend, I worked all day on a weld/fab project with my brother had dinner, crashed for a couple of hours, and then headed home. The failure happened at 0300 on a cold and lonely section of the turnpike, the bridge had a massive breakdown lane, and that made it better. I swapped in the spare and kept on trucking. Yesterday I did a head count of the # of failed bolts, 19 had snapped in the same way the others before had. I figured the only thing left to try was the spacers to get the mounting surface level or closer to that of a thick bead. Time will tell if the BL's were worth the extra hassle.
Since adding the beadlock spacer (4 pieces of ABS plastic that match the curve and bolt holes of the wheel) I have not had another problem with sheared bolt heads. These could be easily be 3d printed and made out of other materials. But for $17 a wheel, it is cheap piece of mind.
