Wow! What a transformation. Good work.
I see your point. Make sure you check the air bags in the back to make sure the air bags are not cracked, otherwise you'll need new air bags. If the ads are bad, the new air pump will burn out from constantly trying to keep the pressure up in the leaking air bags. Use soapy water and look for bubbles once you put the suspension in the highest position. If that's the case, definitely just do spring conversion for the back and keep the adjustable shocks on all 4 corners.Thx Max. Yeahh but im too far now since i replaced shocks in back. I might pull a triger on aftermarket compressor for 150$ ... i spent a lot already so i dont want to go different route. I think compressor was on his last streight .... im pissed but it is what it is..
If that sucker will not lift my truck that means springs will be order same dayThanks Max u helping again. I didnt know springs can work with oem shocksi think airbags holding great. I have truck for a month now and never noticed leak or lowered truck after night for example. I left car many times for like 30 40mins running to burn as much as possible of old gas. Even after sitting a year car maintained height.
That will be last call. I order new aftermarket compressor it was 130$ with rebate. Will see at sundaymeantime i will do left front brakes and take off old compressor
