2001 LC head unit into an 80???
It should connect using the second set of connectors, the width I don't know, I tried to fit a stereo from an '01 celica, the connections worked fine and it mounted in the dash fine, but the dash trim did not fit around it so check that first before unbolting the original.
Ross
jUErI
It should work fine with the mounts and since it looks like flush mount behind the trim like the stock radio should be ok
I put a 05 Camry Navi in my 96 and I had to trim the surround but looks and works fine
My 98 LX had the same/similar stereo. I think the 6 disc changer is a frequent failure point on those, I know mine did, and a search revealed a few others with the same problem. I guess it might be worth trying, if you already have one on hand. Otherwise, I would just buy a cheap aftermarket head unit with MP3/Ipod capability.
I would like to know as well.............I hope this works.
i think the JBL has a separate amp IIRC. If it does you will need to install the amp for the JBL. Good luck and keep us posted. Heck give it a trie and let us know.
