For Sale 2000 Toyota Land Cruiser, Columbus, GA
GA
2000 Toyota Land Cruiser 100 series
221k miles, runs great
Leather
Sunroof works
2.5 OME medium rear Springs with OME shocks f+r
295/70/18 Nitto Trail Grapplers/18" Tundra wheels
MagnaFlow muffler welded
Drilled/slotted rotors F+R
A-TRAC w/ center diff lock
A/C and heat works great. Front and rear
Third row seats (not in pictures, but I do have in storage)
I replaced timing belt, tensioner, and water pump at 220K miles.
Has dings, dents, scratches. Previous owner rear ended a truck, there is damage to the front end. No frame damage, no air bag deployment. It was pieced back together, it's not a show winner. The windshield has two rock chips that havent spread in the two years Ive owned it. The interior has normal wear and stains for 17yo vehicle, no rips. The passenger CV could use a new rubber boot, CV is fine. There is still a stock shock on the rear, I have the new OME shock for buyer that just needs a bushing to install it.
Only thing I can think of that's doesn't work is 6 disc doesn't play CD's.
Location Columbus ,GA
$6700
Text is best, 706-565-9 five 3 two
Very nice! Any leaks? Do all windows, mirrors, seats, locks function properly? Where did you purchase? Any history as to where it has been all its life? Car fax?
No leaks that I know of. When I first purchased it I tightened the valve cover bolts because oil was seeping, it fixed it.
All windows, mirrors, seats and locks function correctly. The driver seat lumbar motor is weak, you have to lean forward and let it do its thing without pressure.
I purchased from a lady here local. I believe I am the third owner and it has been in Columbus GA all its life. I can provide VIN through text message if anyone is interested.
I sent a text and is said the number was a landline?
My questions are, any rust? Underneath pictures? Any issues or fixes every performed on the transmission?
Also, you stated that the timing belt was just changed. Did you do that yourself or a shop? Would assume records if a shop correct?
Thank you!
Well crap, I put the wrong phone number. And it doesn't look like I can edit.
706 566 6 five 9 three is the correct number
There is no rust. I've never had anything fixed on the transmission or anything. I changed the waterpump, tensioner, and timing belt myself.
Paint chips, Only rust I could find, wouldn't really consider it.
Damn bud. this is a hell of a nice truck. GLWS
