Tangent, and not intended to derail the thread, but I assume folks have fit 4BTs into these guys?
Because I have prior conversion experience with the platform and enjoyed it. Bolts even stayed in place.Yeah, that’s a tangent.
Why do people keep asking about this engine going into all manner of vehicle? The 1VD is arguably underpowered for 200-series use on American roads, and the most potent version makes 268hp. A 4bt makes 105. 27% of stock 3UR output.
And it’ll rattle the whole vehicle so much bolts will loosen up by themselves.
There are a ton more reasons this isn’t done.. I’m genuinely curious why it keeps coming up...
I don't know if that will ever work with a 200, unless you replace almost everything else. The transfer case, trans, ecu, and whatever other wizardry there is in the wiring would need to get the signals/responses it wants for everything to work as it should. Older cars don't have that so it's easier to do a swap, but I feel like the 200s would require everything else to be changed.Because I have prior conversion experience with the platform and enjoyed it. Bolts even stayed in place.
Easy to work on, been dropped into a lot of offroad platforms, better mileage with a tune... I'll bow out I suppose. Just thought it was worth asking.
Seems like the perfect time for this....
Home - PPM Racing
Get top-quality crankshafts, connecting rods, and forged pistons at PPM Racing. Our cutting-edge technology, including CNC machining and computer-aided solid modelling, ensures maximum strength and weight savings. Choose from 2618 or 4032 grade aluminium alloy, with hand de-burred pistons and...www.pureperformancemotorsport.com
from what they told me.... the cylinder spring on #5 broke off and got into the combustion chamber, which caused the damage.I'm wondering what happened here. A valve spring broke and the valve dropped into the cylinder?
Thanks! Stay in touch, please. I may consider selling it .... depending on if Corporate steps up to the plate to help cover the majority of the costs.Many reports of Diesel Toys doing shifty operations.
Also, second dibs if you sell it.
Whether they decide to do a rebuild or swap there's already going to be labor associated with that...I'm curious what the power gains are like with this kit. Seems cool but very expensive especially when adding labor and tuning.
Thank you! This is helpful to know. The service team has been really helpful going to bat for me- so they are vouching that the engine was clean and serviced properly, etc. My 1994 LC was actually purchased there and all our services at this same Dealership for over 20 years. They had even just done the oil change on my 2014.Some years back I bought a certified used MR2 Spyder. The transaxle gave up only a month or two after the warranty expired. Toyota corporate paid for all parts (to include stuff like new motors mounts, new clutch, etc. They even upgraded the transaxle to include limited slip when original box was not. I had to pay the dealer labor bill. It helped that I was at the selling dealer and their service manager followed up my contact with his own. Long story, but point is ask the service manager if he will throw in his two cents to corporate - they all know a 5.7 Toyota motor shouldn't go at that mileage. Oh, and BTW, they told me they would have picked up labor too if I had been using the dealer for maintenance service (I like to change my own oil, etc.).
Thank you! I agree. No engine (let alone Toyota LC should seize up under 100k miles, in my opinion). I do have all service records, including good CarFax from PO and it's a super clean vehicle.... so honestly don't think it was ever abused. Just a crazy freak thing (per my husband!)Retroactive Toyota Platinum VSA?
FYI I think the used low mileage motor that @indycole ended up with was something like $15k installed by the dealer. Not new, but I think a ~even swap (in terms of wear/life) and about half the cost of a new motor (plus labor). Obviously $15k is still a huge number.
$85k vehicles shouldn't have a motor implode after 58k miles. Valve springs don't typically break. I do wonder a bit if the PO abused the engine, pushing it up against the redline a bunch or something? I would definitely push Toyota corporate for this, especially if you have the maintenance history available through Carfax and/or the Toyota Owner's site. It's worth arguing as well that while the amount of time in the 5/60 powertrain is >5 years, the mileage isn't.
I'd personally settle for a low mileage used motor from a wrecked Tundra/Sequoia out of it if Toyota will swap it and warranty the result.
Thank you for sharing! This gives me hope that Toyota steps up and does what is right too!!Similar situation, but different...
I bought a commuter brand new - 2013.5 VW GLI. About a year outside of warranty and about 5k miles outside, my timing chain tensioner (oil pressure driven) failed causing the cams to jump and effectively grenade the motor by valves dropping into the cylinders. Started it up to go to work with heavy, what I thought, misfires, and shut it down.
Now VW was a royal pain to deal with, but they kept throwing the "we met our obligation" because it met the warranty expectation - it just failed immediately thereafter
After proving it was rigorously maintained with an accelerated plan, I eventually agreed to pay about 25% of the parts cost for a new one and they covered the remaining 75% and all labor. I HAVE to imagine that Toyota would step up for what is perceived as the most reliable brand. Could make for some bad PR...
I would do a documented yard motor , going new Toyota if you look up a long block was 28k .... whats the price on the cheapest 2wd stripped tundra with a 5.7 ... mid 30’s
Thank you! I miss my 80 Series- never failed! I honestly don't think it was abused and just a super freak occurrence ... and I guess my bad luck.Truly sorry to hear about this. I’m sure it’s very disruptive to you and your family. The Cruiser engine should never fail unless it was horribly abused (not saying you did).
I’d go new and wouldn’t consider a used engine. To have it rebuilt is tricky cuz there could be damage elsewhere due to the seizure.
Sounds crazy but if I had the funds I’d consider going the experiment route and dropping in a diesel.
Thank you! I am going to keep after Corporate and hope they make it right.^^This
It sounds like you are already down this path with the request to Coporate but if you are the original owner and you have service records Toyota might work with you on this. When an emissions component went out on my wife's RX450h a few years ago, which was a 2010 and <60k miles, Lexus just up and replaced it no charge when I complained that there is no way it should have failed at that mileage regardless of time. I can't remember if it was the evap canister or something else, been a few years, but it was expensive enough that I would have sold the car rather than replace it.
They had to clear it through Lexus US, they couldn't make the call to replace it free of charge locally, but they got an answer in just a day. Of course Lexus might have known that there was a systemic problem or something and thus had a default answer of just replace it, but still it was very good of them. They certainly weren't under any obligation to replace it.
I'm not saying that Toyota might give you a new engine and free labor, but they might work with you on price if you are the original owner and have service records. This is one reason that I use the dealer for scheduled maintenance through warranty period and then do my own oil changes in between (I don't care what any manufacturer says about 10k service changes - 5k miles or twice/year for me).
Let us know how it goes. If they don't help out perfect excuse build a stroker or Darton sleeves, upgraded rods and pistons and the big Harrop blower.
Good to know- I think I read something about that too. Thank you!A while back Lexus had a recall for defective valve springs. At the time our LS (also a UR engine) was included but our LX was not. Not sure if this maybe affected 200's at some point?
Hi, I am the 2nd Owner of the vehicle. I have all the service records from Original owner and clean carfaxOP is MIA - has answered no questions and hasn't posted at all since starting this thread.
Hey, @JS Van Slyke , are you still with us?
If so, are you the original owner of your 200 series with the blown engine?
