200 Series and Tundra wheels on 100 series photo thread
You can see where the hub was hitting and left the small indents.
Is that the front wheel spacers? If yes that’s the wrong part.
The correct spacers for the front for a 100 series has cut outs to clear the hub flange nuts.
You only need these specific types
you can still use these in the rears of 100 series.
Confirming that 4 fronts from Slee will work. When I bought mine rears were out of stock so Slee suggested I buy fronts all around.
Nice, so I’m good to go with 4 fronts then? Thank you for looking into it. Im gonna put in my order today with them.
Here’s what Ben from Slee told me before I purchased last year:
The rear wheel spacers are on backorder again and will not be available until September (aluminum shortage). We can use a set of fronts on the rear if you like. They are the exact same spacer with more machining and slightly more cost.
Awesome, I ordered two sets of the fronts today from Slee.
One more question - will the lug nuts that come with the Slee spacers fit the HE TRD BBS wheels or do they take a specific kind/shape? Or is there a preferred or better set of lug nuts for the trd BBS’s? Also given the cost and somewhat rarity of these wheels do most guys run locking lug nuts? Are scumbags targeting these wheels for theft at a higher rate?
Here is mine with 2015 trd tundra 18s, the tundra center caps fit perfect with 1 1/4" spacers. View attachment 1134434View attachment 1134435
Sorry, I know your response was from 2015, but hoping you remember...I see your TRD wheels here and believe these have an offset of +60, which is the same as the stock 16" LX470 ('99) wheels. I am curious why you got the spacers? Just to pull them out and get inline with the body or are they there to avoid rubbing? I am eyeballin' a used set right now and curious what adjustments I need to take to get them in use. Cheers!
The spacers are to allow the center cap to fit. The wheels fit fine without spacers, but the center caps won’t snap into place on the front due to the 100 Series’ grease caps.
You can install a spacer, modify the grease cap (crush with a hammer), modify the center caps (remove material with a dremel) or run the wheels without center caps.
Thanks for the deets! Is your rig lifted and what tire size are you running?
My truck isn't in this thread as I run OEM 100 Series wheels...
TRD BBS forged on my silver LX470. These do require a spacer as mentioned earlier due to the tapered hub opening. I’m running Bora 1.25” front and 1” rear. 275/65r18 Michelin LTX A/T2 tires that are stock on Tundra I believe. Very very nice manners for these tires on road, not sure about off-road yet!
Those look good man!
White letter would make it pop a bit more also, if that's your thing!
I agree, i spent 3 hours with a white tire marker on my tires, all 4x4 needs white letters on the tires!
Also, I have the stock 16’ wheels which are corroded and horrible for the winter set. Cant run steelies during winter here, they use brine solution on the roads.
So my next purchase will be something like those for the winter set, just abit hard to find 5x150 in Norway thats not sinking my budget completely.
