2.5 Installation
Ca
I was able to finally get my old shocks out after a lengthy battle. Now on to the next issue
My icon 2.5 shocks came fully extended. How are supposed to compress these things enough to pin the bottoms? Anybody know?
Man up. lol. Actually I had the same problem with my first 2.5's from a different manufacturer. I had to let the nitrogen out to install them and have them recharged after.
I installed my shocks while installing new springs, so I had my suspension extended enough for the shocks to bolt up while extended.
Im doing the same thing. The front is dropped and the springs are out. These things still need ti be compressed 3" or so at least
I'm doing the same thing. The front is dropped and the springs are out. These things still need ti be compressed 3" or so at least
If your brake lines aren't tight, you may be able to extend your suspension far enough to bolt on the shocks. If you can't compress the shocks manually, you could try putting a bock under the bottom of the eye and lowering the truck until the eye lines up. Depending on how slowly your jack lowers, you may have better luck after you lower just too far and are jacking the truck back up.
The axle should drop plenty, what's limiting you? Brake lines?
Not sure at this point. Its not the brake lines, maybe the stableizer bar or panhard?
I just measured and I have 28" from the bottom of the upper shock mount to the top of the bottom. The shocks are 31" from the bottom of the upper threads to the bottom of the shock.
Im gonna try and see if I can jack it up with wood or something soft and narrow since the bottom of the jack wont clear the area it needs to go up through. Not sure if I can get it out in time though and it wants to cock eye when I start jacking it up
I was just doing this during a castor plate install. Make sure it's not your driveshaft hanging up on your sway bar.
I just disconnected the lines running down the DS control arm. That seems to have given me a little more play. Ill see if that works.
I’ve done two ways
One use a jack and have the shock bolted in on top then jack the bottom up to the hole and smack the shock off the jack into the hole or on the to the rear stem.
2 method is put some zip ties together and put all your weight into the shock and compress then zip tie it once started you can make tighter to compress more.
You need to be careful with either way
Sway bar is disconnected
Disconnected from the axle or the chassis? If it's still hanging on both of its hangers to the chassis, the driveshaft can still bind on it, even if it's disconnected from the axle.
I left it connected to the axle and disconnected it from the chassis. I followed the directions from Slee for installing the OME suspension to drop the axle. Slee - OME Suspension Installation (Toyota 80 Series Land Cruiser)
Plus I disconnected the brake line from the center of the axle and the line running along the DS control arm
I'm going to try and get the shocks inn again after work tomorrow since I didn't get a chance today after taking control arm lines off.
Ok, one more tip, not sure about the Slee instructions, so sorry if I am being redundant. With the axle dangling at full droop, jack it up a couple inches and put a jack stand under the side you aren't working on, then have a friend stand on the hub while you wrestle the shock. The jack-stand on one side gives you some leverage.
I just installed my King’s 2.5 and it was definitely a pain but doable.
Front: I was able to compress it enough put the shock through the eye on the axle and then top. They have a lot of rebound so they extend slow, even if you miss the top eye you should be able to pull it down a little while laying on the ground.
Rear: rear is far more difficult, I was able to put all my weight on it and compress it slowly, wrapped the shock with strap and finally got it in.
You should be able to put all your weight on it and compress it, won’t be easy but doable. It was very hard to compress it even though I weight in at 210lbs.
Thanks for the tip. I will give that a shot
Also if you have really tall jack stands the jack up the frame as high as you can and put factory bottle jack between the axle and frame. Don’t jump on the axle especially if you don’t have the frame 100% secured with really solid 10 tons jack stands or shop lift.
I was able to get them installed today. I ended up cutting a piece of 2x4 and putting it between the jack and the bottom of the the shock. The 2x4 was was narrow enough that I could jack it up and get some height over the bottom mount and quickly push it off and into the hole. Thanks everyone for their help
