@Nikofzj80 : The internal parts, especially the plunger, are different for the 2.2kW starter compared to the 2.0kW starter, so if the shop that rebuilt your 2.2 starter used the wrong plunger it will give you problems (not cranking when hot for example).
Here's a photo showing the different size starters.
The 2.2kW starter came on the 1993 FZJ80 models (only) but any of the three will fit a FZJ80:
Photo below compares the plungers for a 2.0kW and 2.2kW Denso/Toyota starters. On the left is the plunger for the 2.0kW starter, plunger for the 2.2kW is on the right (don't have a photo of the plunger for the 1.4kW)
Here's the thread:
I pretty much remanufactured a 2.2kW starter awhile back, new armature bearings, cleaning/greasing the drive assembly, sanding/cleaning the armature, replacing contacts and plunger, zinc plating the case, replacing O-rings, new wire insulation,---. But after a few months I started to get the...
forum.ih8mud.com
