1KZ Nightmare
Well the temp gauge had been running up and down for a while and using coolant
so on 4th Jan went out to the workshop and pulled the radiator out and yup full of mud at the bottom. So took it to the radiator shop and they cleaned it and pressure tested it and found yet another leak, fixed and then re-installed and filled with coolant. THis radiator only a year after being fully recored :( Intercooler to be added after the Volvo rebuild is completed in 6 weeks.
so then 14th was a holiday so we decided to have a BBQ picnic in the jungle family day wives and kids. Checked the radaitor the night before and topped it up.
First disaster of the day was a HILUX which poor guy pulled the lead off the second battery I fixed it with a spare lug and my crimping tool. took us 45 minutes to fix.
On the way up the 750 meter climb the gauge rose as normal and slipped it into 2nd and cruised at 3000rpm and the temp gauge started going down then with 500 meters go go I saw a puff of steam out the front of the bonnet then backed off and looked in the side mirrors SMOKE and STEAM everywhere. The guys behind me said it just blew.
Stopped and found the problem RADIATOR hose off the BLOCK which we had not undone. So refiited and tried to fill the radiator but we could hear the tink tink of metal moving/cooling rapidly.
REfilling the radiator showed a leak on the bottom hose into the radiator - refitted the hose and still a LEAK damn somewhere where it has the clamps for fitting to the car body has a leak. Guess thats why it blew.
Drove the wreck tot he top of the hil and parked it at MACDonalds and put all the BBQ kit into a STOCK MITSUBISHI TRITON and sat in the passenger seat - cry cry cry. Wife into a passenger seat in a ZOOK.
BBQ was a success considering the terrain the stock MISSBITCHY never got stuck but the stock PAJERO did and was aided by the ever present DAFFY the HILUX SURF.
So we got to the PIcnic spot 2 hours late 12pm sigh. Deep fried turkey (yes we took a deep frier with us) and sausages and chicken and hamburgers cooked in the kettle BBQ.
Then 5pm full of BBQ food packup time (2 hours late) got the tarp put away as it started to rain rest of the kit put away in the pouring rain. No more stories of my trips on this forum as Brownbear has told me to move them to Chit Chat section.
Then off to collect the BLue wreck.
It started very badly and poured smoke everywhere and made horrible noises and the radiator still was leaking dripping out from somewhere hidden cry cry. TOW truck
waited 90 mins for the flatbed . 10pm home 4 hours later than planned.
Looks terminal and worse I have no car RED is in the hospital the gearbox is being removed and looked at as it still does not want to go into 3rd or 1st after the rebuild and it's blowing grey smoke just off idle and at startup. So far we have discovered rust in the fuel filter and it needs a new fuel tank. The aneroid pump is being adjusted also. I have been told can have it back tonight and he the rawang doctor will take BLUE in for surgery.
Mrs wifey was thrilled being in the tow truck since when loves trucks. Then I told her the cost of this ride somewhere around 7500rm (or $2000USD) so she better enjoy it.
So its been decided I have had enough of 1KZ engines BLUE will be repainted and repaired and sold and we will keep the mighty TROOPY instead. Mrs wifey agrees.
Now we gotta source a new engine again or rebuild the old BLUE engine which I kinda prefer. I did not wanna spend any money on BLUE while I was finishing the Volvo its in the final 6 weeks of the rebuild and is close to being started and running.
YEsterday was a holiday so dropped into the workshop to collect RED and see how the disgnosis on the dreaded Blues 1KZ was going.
Looks like cracked head as a minimum. So the old head will be pulled off the previous engine since it was brand new and then the current engine head removed and see what damage there is :(
Also new alloy radiator coming the old recored one just cannot be trusted anymore. I am tempted to get one from Summit racing as the china ones here cannot use coolant in the alloy radiators they corrode away.
Dougal loves this engine, ask his advice on what to do.
part of the problem is the mud in the rad. when you are off road, is it just mud and water? silt and water? vegetation and water?
if it is silt, it is pretty hard to keep it out of the rad. but a mosquito screen on a removable frame work in front of the rad would help. this way when you come out of the hole, stop, lift the hood and pull out the screen, rinse off in the creek and reinstall.
this does not help the silt from the back side.
i also install an expanded aluminum sheet in front of the rad, this smaller squared hole sheet helps keep the mud and mostly rocks and twigs away from the rad. i install them front and back of the rad. i lost a rad, and a wheeling trip, to a stone that came up off the tire, hit the fan and went through the back side of the rad.
something to think about.
I have sorta lost track.......
Is this the 1st or 2nd time this particular engine has let you down?
some people live and learn ... some just live.
he is learning.
Another good Wayneism ..............
I hope you are writing these things down somewhere so you can pass them along to the next generation. :D
nah, when i die ... mud will hold my eulogy and tribute of sayings ...
<unless Woody suddenly decides to delete my memory.>
Probably depends on how much "bandwidth" is required to "remember" you. :D
Second and second engine and 3rd head sigh.
More later
In a lighter moment
I managed to find the big switch I hope to use as a STARTER button in the Volvo - yes its 3" in diameter lol.
Then the kitten knicked the measuring tape and clawed my bag to death.
In this case it was sloppy mud full of silt and busted up leaves the back side is just full of mud and crap. THis mmudhole also cost me my central locking all the actuators melted when the muddy water filled the drivers side footwell.
and I was in there a while since I had run over the winch cable sigh.
I hosed the radiator out at home after removing the shrowd etc but still not enough.
Part of our problem is the HEAT normal day here is 90f+. ALl of our 1KZ's have had issues recently with HEad gaskets and worse busted blocks.
We also hosed the radiator after coming out of the trail at a car wash and still it did not get enough mud out.
Putting anything more in front of the radiator would just hinder any cooling. I am toying with installing a bilge pump to pump fresh water through the radiator after deep mud holes.
I think I am going to have to be prepared to pull the radiator out in the field in future after deepmudholes and use the 12v bilge pump idea to pump water under pressure to clean it out.
Change over to utes and run the radiator on the try
Not many live axle utes here except LR rubbish
Hj75 is commercial only veryfew mods can be done to them.
the point was REMOVABLE mesh.
the silt will go up against the mesh and stop.
once out of the hole you remove the mesh, shake off the chunks of silt, rinse and reinstall.
you will still get the silt from the back side but with the fan running the pull won't bring in silt from the front plugging the rad.
it was only a suggestion.
you are still running the fan shroud right?
I will have a look at this idea
yes I still run the shroud the climate here it is a necesity
excellent, just asking. many wheelers i know take it off for easier cleaning of mud after a run but then the fan is no where near as efficient.
cheers
