Super easy to test for air in the fine system with a $10 piece of clear pvc hose between the filter assembly and your injection pump. Takes 10 minutes to set up.
If you see bubbles pass through the clear hose, you have air in the system.
A piece of clear hose from the firewall to the filter will tell you if the leak is in the primer/filter assembly, or somewhere between the tank and filter. No bubbles before the filter, but bubbles after equals leaking filter assembly.
Bubbles before the filter equals leaking fuel lines under the car
