There are so many factors that come into play, this could be a moot point.
The known issue of the FIRST head gasket, of course.
Then there are valve seal replacements.
Then there are the recommended service intervals. Those are listed in the FSM, but have already been exceeded by many on here.
My truck had the HG replaced and the head rebuilt at 145K. It now has 276K on it and all is in excellent shape and does not use oil. However, I am a DD and a mall crawler.
Those in the deserts of Africa will have a very different longevity compared to the Mall Crawlers of America......
If a vehicle sits for weeks at a time, that is VERY hard on rings, bearings, and seals. The oil drains down and starts up dry, the acids in the oils attack bearings, the stagnant fluids don't circulate and are allowed to have an electrolytic process act on the nearby metals because they don't move. The moisture in the ambient air migrates in and out of the block through thermal cycling and causing moisture integration in areas that would normally be hot enough that the moisture would not even be there.
Read in my sig line about dis-use.......
