Did the deal on a Haas VM-3 today. Have to move it and get setup. Should have bell housings sooner rather than later.
^ buried in the fine print
Months@gonzopancho when you say bell housings sooner rather than later, are you talking weeks or months? I have not ordered the H151 bell housing yet, the engine goes to the machine shop next week and I'm hoping to get the swap officially started by the end of January.
Months
Lizard Skin has to be sprayed.Copy that. On a related subject to the swap, do y'all have recommendations on sound/thermal insulation I should put on the firewall and transmission hump while everything is out? Lizard Skin comes to mind, but I haven't worked with it, nor do I know anyone who has an opinion locally.
Aluminum face, fiber insulation with an adhesive layer. We use something extremely similar on our turbo downpipes and it is LEGIT for keeping heat at bayLizard Skin has to be sprayed.
I’ve done trucks with Lizard Skin, snd my opinion is it works pretty well, but if spraying isn’t an option, @Cruisers and Co can tell you what they used on the piggie
For those pursuing this 1FZ-FE swap stuff into older cruisers I can say hands down it is my favorite platform to date and will be putting one in my 40 at some point.
Better in a few ways, sure.So the expectation is a perfect 1FZ bolted straight up to an H55F?
I though the 5speeds that come with the 1FZ overseas were better. (H151F?)
I am looking for a 1fz to H55 bell housing / adapter. Are you making them still? What are you asking per, and do you have an idea on lead time? I've got a 71 FJ-40 sitting with no power train. I've had the H55 and transfer case for awhile but needed the missing link, the bell housing. Thanks.Haltech (the 750 won't run knock sensors) or ECU Masters EMU Black.
Sniper is just a glorified carb. Real EFI with the injectors near the ports, is the one true path.
I have one, and have already scanned it.
I plan to make them, yes. It’s behind other projects atm. I do have a scan and a whole setup.I am looking for a 1fz to H55 bell housing / adapter. Are you making them still? What are you asking per, and do you have an idea on lead time? I've got a 71 FJ-40 sitting with no power train. I've had the H55 and transfer case for awhile but needed the missing link, the bell housing. Thanks.
