Based on a recent conversation I had with a well-reputed Cruiser shop, I am considering swapping out my 250K/23yr old engine with one that they would source and rebuild. I'm only considering this because I trust this shop backed by ih8 references.
I would require that they source an engine same model year ('97) with lesser miles. Should I go this route, it'll save me 2-3 weeks of downtime as the shop itself is in Norcal and I live in LA.
Costs aside, what are some of the technical pros/cons of going this route rather than dropping off my truck and rebuilding the original engine?
Underhood-wise, I've already done quite a bit of preventative maintenance with OEM parts whenever available.
Radiator / hoses / fan & shroud / heater control valve / Wits' End fan clutch / plugs / disti / wiring / accel cable / battery / starter / alternator / belts / phh / valve cover gasket / Wits' End MAF / intake tube / fuel filter / brake booster / master cylinder / power steering pump / water pump / etc
Work to be done would be the obvious stuff like HG, refreshed injectors, all new gaskets including RMS, timing chain cover, upper arch pan, decking the head, servicing anything internal that needs attention. I'd probably ask to do some extra things like new engine wire harness while in there, engine/tranny mounts, etc.
Current symptoms are engine knocking under load and eating about 1 qt of Mobil 1 5w-30 full synth every 1-1,200 miles. Otherwise, smooth, no odd noises. Desired goal is like new engine good for another crazy amount of miles and years of pleasure. Add Wits' End turbo kit once verified all good.
Thank you.
Thank you.
