Are you using reusing the bolts or new ones? They are 14 bucks each!
20 yr old head bolts "IN SPEC" okay.
$750. spent on the head to wreck it hahaha
I can't wait to see the finish bawww IN SPEC.... IN SPEC...IN SPEC..
This is a good time to test all the sensors that are in the side of the head as well the VSS's. This is outlined in the FSM.
I strongly recommend the use of an accurately calibrated torque wrench, especially for the head bolt or studs whichever you decide to use.
Crank them old head bolts back down till they stop, maybe 110ish lbs.
FSM and "specs" please.
accurately calibrated torque wrench" stop the BS.
Torque value is for assembly plants and all new stuff.
A 20 year old truck requires common sense.
good stay home
29lb/ft and I would not have said it if it were not the case. Glad you caught it because this ain't your grandpas 1950 Pontiac.If you dont have a torque wrench you need one. I use mine all the time. But i think the head bolts go in with out the torque wrench. I did mine by the FSM with 90 degrees twice pattern.
edit, Sorry but you are right. I torqued them to some low number BEFORE doing the 90 degree turns. yep, you still need a torque wrench.
