1f - 2f differences.
Is the bellhousing bolt pattern (block - bellhousing) the same between F and 2F's?
is the flywheel the same size between F - 2F?
Bellhousing to motor is the same at least on USA trucks.
The flywheel is different. You can use either flywheel, but you must have the correct clutch. ie use the 2F clutch with the 2F flywheel.
Flywheel is different, but they interchange. As Andrew said you just need the matching clutch.
Bellhousing bolt pattern is the same.
Not to hijack, but what about the slave cylinder? I am going to a 3sp bellhousing on my '78 for a 465 swap. Will the slave be the same?
:beer:
:beer:
Clutch slave cylinder is the same and can be mounted on either side depending on your application.
is the flywheel diameter smaller on the F?
No, but it is a bit heavier and is stepped. Most folks say to use all 4 speed clutch components due to the smoothness of the diaphram pressure plate. However if you want the best lugging ability then use the 3sp stuff. Just make sure to check the fingers for proper adjustment!
The flywheel is NOT different.
F engines came with either the heavy flywheel & coil spring clutch, or the light flywheel & diaphragm clutch.
2F engine only came w/ the diaphragm clutch & flywheel.
Use whichever setup you have/prefer.
well that just shot my theory out the water.
I have an adapter plate to adapt the bellhousing to the non-toyota motor. i know it's not a diesel bellhousing adapter (have one of them too, just no diesel bellhousing). the starter doesn't line up... and my theory was F's had a different flywheel... looks like my conversion kit is just sh!t.
