Build 1997 FZJ80 to HDJ80 1HD-FTE + H152F
Could you share a link to that gauge?
I'm thinking about using it to measure the head temperature.
Does it come with a probe I can attach to one of the head's bolts?
It’s an Auber gauge. Check their site for all the info you may need. I’ve had that gauge and currently have the same one but in round form to monitor trans temp.
Elegant. That is all... :cheers:
Power steering cooler.
New 105-series steering box.
More is in the works as well!
Cheers
Checked both block deck and bottom of the head, just to make sure.
Torquing it down right now. 🤙
Cheers
Head is on with ARPs.
Got a set of cam bearings coming, they are cheap so we figured why not do them.
That’s it for now on the FTE until the coater is done and a few parts arrive.
Cheers
Whole underside of the body got scrubbed clean the last few days. It’s heading out for paint soon so this was prep for that.
Cheers
Made a body cart today, mostly for this build. It is fully adjustable though and will work on a 40/55/60/70/80.
Just need to do a half dozen tack welds and some big flat washers and I can set it down on the cart. The body shop it is going to is a ways from my shop and we don’t want to transport the body on the rotisserie. It will get transported on this cart and he can use both the cart and rotisserie for the full paint job.
Cheers
Cam bearings came in so today the cam and rocker assembly got installed. Valves adjusted as well.
Fresh back from the coater, ceramic.
Cheers
